Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9Z Condition Priority...
Old 12-05-2005 | 04:31 AM
Default 9Z Condition Priority...
Hello Krysta and Bax,
I ask you sorry for my numerous questions about 9Z, but I'm going to use it on my new pattern airplane for first year of contests, so I will be very glad to understand it in depth, and I find the manual and documentation a bit superficial on some areas.
The first question is condition priority: could you please tell me something about this and how is that concept implemented in the 9Z? I've browsed all functions, and I didn't find one regarding this issue (if I recall well the 14MZ treats this issue directly)
Also, I would like to better know what are Hovering type mixes. I don't understand the manual on this point, perhaps an example will clarify this! I've read also your GREAT GREAT guide "Getting to know the 9Z", and it says a very interesting thing: it is used to fine tune another mix. At first, I thought it was something similar to CTR mix... the guide says to refer to hovering throttle and hovering pitch functions of hely. Albeit I'm flying with airplanes, I've checked those function and understand it: I can have a VOLume that control throttle curve in the certal position. Ok. But when I go to airplane and choose HOVering type mix, there is not the same semantics IMO: I have to chose two channels, but I don't see how this mix can helps to fine tune another mix (function that I would LOVE if it exists!!!)
Guys, I really appreciate your help. I understand the question is not quick and simple, so... I'm ready to wait!
Have a good day!
Old 12-05-2005 | 10:28 AM
Default RE: 9Z Condition Priority...
Guys,
I've just found a FAQ on futaba site that explains the condition priority issue: I'm ok with it now!!!
Can you give me an example of hovering mix for an airplane use? If my question was not clear, I understand what it does regarding offset and rate, but I don't know how to fine tune another mix with it, with respect to airplane programming...
