Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Mixing to Elevon
Old 12-14-2005 | 02:23 AM
GoeKeli's Avatar
My Feedback: (18)
Default Mixing to Elevon
Bax or Krysta,
I am setting up a delta wing jet and have elevon enabled. I want to mix elevator to a vector thrust unit and use it on a switch. I can't seem to get the vector channel to link to the elevator. I've read the manual and the futaba website but still am not sure what I am doing wrong. Please help.
Joe
Old 12-19-2005 | 12:09 PM
Bax
Default RE: Mixing to Elevon
Which transmitter are you using? It can make quite a difference.
Old 12-19-2005 | 12:12 PM
Bax
Normally, you would make a mix of Master->Elevator, Slave->vector unit. Use the switch to turn the mix on and off.
What transmitter are you using, and what are the settings you've tried?
Old 12-19-2005 | 06:48 PM
GoeKeli's Avatar
My Feedback: (18)
Hi Bax,
I think I got it figured out. I am using the 9C and I made a mix- master elevator slave flap and used flap as the vector. It works and is on a switch, when activated moves with elevator and when deactivated centers. I'd like to use expo with just the vector/flap. Is there any way with the 9C to assign expo to flap?
Thanks for your help
Joe Kelley
Old 12-20-2005 | 11:09 AM
Bax
Sorry, exponential is available only on channels 1-4.
