Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Dual Rate Switch Problem
Old 11-17-2002 | 07:18 PM
Default Dual Rate Switch Problem
I have a 6XA with Futaba servos and the Futaba 127FM RX installed in an Easy Sport plane.
Somehow in setting up the radio I have reversed the elevator dual rate switch . I can't figure out how I did it or how to correct it. Any suggestions?
Old 11-17-2002 | 10:01 PM
Cassidy, you set the 2 switch positions yourself....you set the rate by putting hte switch in teh desired position, setting the desired travel, set the switch in the other position, set the desired travel. just reverse the %s if you're not happy with them.
