Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Programming the 9c
Old 01-01-2006 | 08:11 AM
Default Programming the 9c
I would appreciate any help with programming flaperons on a 9c. The reciever is in a Great Planes U-Can Do-3D 60. I have been able to program other functions, ailerons, elevaters, rudder, etc but when I try to program the flaperons I can't seem to get it done. Thanks
Old 01-01-2006 | 09:32 PM
My Feedback: (20)
Default RE: Programming the 9c
To start with you have to go into the advanced menu, go into the Flaperon program. From there you have to highlight the INH next to MIX. Rotate the dial and change INH to ACT to activate the flaperon program. You should be using channels 1 and 6 for flaperon to work. There is a option to use channel 5 if you do not have a 6 channel reciever.
Once activated, you can set the rate percentage if you want something other than 100%. You may need to change the direction of channel six servo if both servos are going in the same direction.
You can now activate your airbrake program for tight loops and/or use the flap to elev mix to add flaps for slow flight, landing etc.....
Hope this is what you are looking for.
Jeff
Old 01-01-2006 | 09:57 PM
Thanks Jeff...I think I am using the wrong rec channel.
