50Mhz Band and Antenna on 9C
RE: 50Mhz Band and Antenna on 9C
The RF output section of the transmitter module is tuned to accomodate the antenna. You don't need a different antenna. This would be true regardless of the actual frequency band you used...no matter where in the world you decided to use your tranmitter. Just plug in the appropriate frequency module and you're ready to go.
