Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
gyro setting question
Old 01-01-2006 | 07:28 PM
bldrums's Avatar
Default gyro setting question
First let me say , I am posting here on the open forum the same question I put to the Manufacturer's forum in case one of our expert members can help.
This is the equipment used:
6XA transmitter
350 gyro
138DP 8ch pcm rx
OBJECTIVE:
to switch the gyro on/off from ch 5 ( gear ) without using Heading Hold feature.
PROBLEM:
Channel 5 ( gear ) switch will turn gyro on/off but my gyro only operates as Heading Hold (AVCS ) mode. I want to use NORMAL mode only.
SET UP:
Gain switching connector/ single wire yellow ( red plug) from 350 into Ch 5 of rx
Rudder servo into 350 and out to ch 4 (rudder) on rx
I get only AVCS MODE when the switch is "on" and ,as planned, no Gyro with ch 5 switch "off"
Can someone trouble shoot my problem with this information??
Thanks All
bill
