Ailvator
My Feedback: (8)
IN
Ailvator
Should both elevators move in ailvator mode when I mix rudder (master) to Elevator (slave)? Right now I have to use a mix for Aux 2 to get the left elevator to follow the rudder. Same goes for throttle as the master. I have a 9 CAP [&o]
Thanks, Lee
Thanks, Lee
RE: Ailvator
Hi Lee,
As long as you turn Link on on your Rudder to Elevator mix, the second Elevator servo should be moving also. You should not need a second Pmix to make this happen. Try your Link feature and let us know how it works.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: Echoes
Thanks, Lee
Thanks, Lee
