Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9C Transmitter Module
Old 12-07-2002 | 03:21 PM
Default 9C Transmitter Module
Is the transmitter module used on the 9C transmitters interchangeable with those used in the 7 and 8u series of transmitters. If so is there a problem with substituting a module for channel 56 with a module for channel 24 on the 9C transmitters.
Old 12-07-2002 | 04:43 PM
Bq, the modules are identical, and that's is exactly the idea of the modular system.s not only can you change within your band, but you could even put in a 75MHz band and use it for a robot, or a 35MHz and go fly in Europe!!
