14MZ Throttle Curve
14MZ Throttle Curve
Hi Futaba
Is it possible to set up a throttle curve for an aircraft on the 14MZ. I have a lot of petrol and 4 stroke engined planes, and I am finding that I am reaching full throttle about mid stick position on some of my models. I have tried adjustments to the servo arms and linkages, but on several models I can not overcome this problem.
If Throttle curve can not be set for aircraft, what would you suggest to eleviate this problem?
regards
14MZ flyer
regards
14MZ flyer
RE: 14MZ Throttle Curve
Hi 14MZ flyer,
Just go into the throttle channels AFR settings. Set it on Line or Spline. You can now set any number of points on the throttle channel as you wish, and make any shape curve.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: 14MZ flyer
Hi Futaba
regards
14MZ flyer
Hi Futaba
regards
14MZ flyer
