Slow servo movement?
ON, CANADA
Hi.
I have a 9Cs TX. When I move the sticks for R,E,and A servos, the servo moves quickly to the spot it should but slows down for the last part of it's travel. This works when centering the sticks too. So the servo moves fast but creeps to a stop at the end of the movement.
This happens with all types of RX and servos I have.
How do I get the servos to move straight to the designated place and not slowdown for the last 1/2 second of the travel?
Rob.
Rob.
RE: Slow servo movement?
Hi Rob,
You do not state if you have any Expo set. I would check this first, or go into a blank model and see if you get the same reaction from your servos.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: Rob-E
Hi.
Rob.
Hi.
Rob.
ON, CANADA
Hi Krysta.
This happens at every setting with or with out expo or any thing else.
It happens on a newly cleared model setting and on a models with many mixes.
It happens with all types of servos and receivers that I have used (at least 4 different brands of RXs and 5 brands of servo).
I was hoping there was some Soft Response setting some where deep in the software that could be de-activated. I guess not eh?
Oh well.
Thanks for your reply.
Rob.
Oh well.
Rob.
