6EXAS and Electron 6 Reciever
I have a Futaba FUTK54 That has the 6exas TX and R156F Rx It works great.. I also have a Hitec Electron 6 Rx that I would like to use in another plane. Now I tried to swap the Xtals with the recievers and I got nothing from the electron. The radio was set to PPM not PCM. I also tried PCM just for the hell of it.. Nothing.. I woud like to avoid buyin another Rx if I dont have to.. I have the Electron for the Hitec and Futaba Tx's W/ - shift
Is this radio compatable with other RX's? if so.. Why would this not work?
Here are the specs on the Electron6
Type 6 Ch. Dual Conversion FM
Range 1+ Mile / 1.6 Km or more
Operating Voltage 4.8 - 6.0 volts
Current Drain 19 mA +/- 3.0 mA
English Metric
Size L x W x H 1.8"x 0.9"x 0.6" 46 x 23 x 15 mm
Weight w/ Case 0.6 ounce 17 grams
w/o Case 0.46 ounce 13 grams
Type Hitec/Futabaâ„¢
Negative Shift
Airt/JRâ„¢
Positive Shift
Mike
English Metric
Negative Shift
Airt/JRâ„¢
Positive Shift
Mike
