T6XHs..trim problem
T6XHs..trim problem
Ok so I get the manual out cause I cant figure out why I cant get any trim for the throttle..under exponential settings it says.."You can make the servo movement less or more sensitive around neutral for aileron,elevator,throttle(except HELI type)..and therein lies the problem,, the throttle trim works fine from half throttle to full open ,,but from half throttle to closed it doesnt work at all so that I cant shut the motor off with the trim...is the radio able to be set up for this?..Rog
RE: T6XHs..trim problem
Hi Roger,
It sounds as though you need to change your Throttle Reverse. Our FAQ for the 6XHS will walk you through this:
http://www.futaba-rc.com/faq/faq-6xsuper-q94.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: flyinrog
