9c Dual rates and Expo
TN
Just got a 9c Super and was setting everything up and wanted to know if dual rates(triple) could be on one triple switch(switch C) and then have three different expo amounts on switch G? Also how can you start a timer with the throttle stick and still have the clock ticking when the throttle drops below the trigger value.
I have not flown with this radio yet but it ROCKS!!!! I love it. Thanks for any help.
RE: 9c Dual rates and Expo
No, the dual rates and exponential cannot be put onto different switches. When you turn on "expo", it's always on. You can set only one exponential curve for your particular model, and cannot change the amount of exponential with a switch. Only the rate can be changed with a switch.
If you use the throttle stick to activate the timer, then the clock stops when the stick goes below the triggering position.
