14MZ Problem
14MZ Problem
Hello.
I got my 14 system about 3 weeks ago.
I study it and today I have tried to install the receiver and to change modulation to G3 2048 and change freq. (72MHZ).
System is not able to change the Freq.
Facts:
1) 14 Transmitter works fine with AM and PCM receivers.
2) New Receiver ID sets properly.
3) I have tried with the DSC cable. The system detects the Cable and shows the connection but still not able to change
and keep beeping and keep sending data to Receiver but nothing happens.
4) Modulation is G3 2048
5) Both Transmitter and receiver are with 72MHZ modules
6) Tried to change to different frequencies but still not change.
Any ideas?
Amram Leshed
Facts:
Any ideas?
Amram Leshed
RE: 14MZ Problem
I have the same problem. Everything works great until I try change Freq.
Now receiver won't work at all.
Now I'm looking for new ideas.
Help!!!
Adam
Help!!!
Adam
RE: 14MZ Problem
HI Adam,
Please check out our FAQ's on the 14MZ, you will find not only information on changing your frequency, but many other helpful tips.
http://www.14mz.com/faq/faq-14mz.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: adamd11pl
Help!!!
Adam
Help!!!
Adam
RE: 14MZ Problem
Recently an unfortunate mishap broke two of the switches on my 14MZ. I sent for and received Futaba switches of the correct function. However, on removing the switch module I found that the switches have a small circuit board attached for the switch plug. I cannot get hold of or find a supplier of the MZ switches. Can I safely remove the small board from the broken switch and solder it to the replacement switch. A simple question and an easy task to complete, but are there any electronic differences between the MZ switches and Futaba switches which fit all other TXs.
Thank You.
Thank You.
RE: 14MZ Problem
Hi Warwick,
We do carry both types of switches for the 14MZ, the ones with the PC boards attached and the ones without. When you order these switches you need to let the rep know which ones you need. These switches are specific to the 14MZ and ones for the other Futaba radios will not work.
As for removing the PC board, yes, if you feel comfortable desoldering the board, then it should be an easy fix for you to do at home.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Sincerely,
Krysta Hunt
RE: 14MZ Problem
Would some one please tell me in plain words how to set up my 14-MZ so that the air brakes matine the settings when they are turned on or off,,
Like the Super Nine Cap,,
