Glider 2 Flap and ability to use throttle?
I have a sport plane(Kangke Monocoupe) with flaps and ailerons set up with Glider 2 Flap in order to use the flaps in conjunction with the ailerons.I want to use a switch to activate flaps,and the throttle stick for throttle.If I set the SW/Mode to "other than STK" the throttle does not work.Is there any way to make this work?Should I be programming in ACRO?
