Mode change on a Futaba 12 Z
CA
I recently bought a Futaba 12 Z mode 1 radio, I would like to change it to Mode 2 . Mechanical change I know but how to go about the software change there is no menu for changing software. Can you help.
Sharad
Sharad
RE: Mode change on a Futaba 12 Z
You will have to send the transmitter to the service center for a full software change to Mode 2. That would include changing the locations and settings of the toggle switches, and setting the throttle stick to the correct configuration.
Otherwise, you can configure the sticks to operate any channel you wish. You would do that in the 'function' sub-menu of the 'Linkage' menu.
You will want to change channel assignments in the Function menu of the transmitter.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
[/quote]ORIGINAL: SHARADEDGE540
Thankx Bax, but will the mixes work the way they should or I will have to swap channels.
Sharad
[/quote]
Sincerely,
Krysta Hunt
Sharad
[/quote]
CA
Hello Krysta,
Thanx for the reply. I would appreciate if could kindly clear one doubt I have , if I change channel assignment in the function menu would the software understand while mixing channels. If you could also explain me step by step change of Mode 1 to mode 2 will be appreciated.
Sharad
Sharad
