Transmitters and modules
OH
One of our club members removes his module when not flying.
The theory is that it is one more step to make sure he has the frequency control pin before turning on.
I like this idea.
However, some folks say it quickly wears the pins that connect the two.
Can you comment?
Also, Mr. Baxter, did you get my PM regarding the 9VAP?
Thanks!
JLK
I like this idea.
Can you comment?
Thanks!
JLK
RE: Transmitters and modules
ORIGINAL: jlkonn
I like this idea.
Can you comment?
Thanks!
JLK
I like this idea.
Can you comment?
Thanks!
JLK
I have got to the extreme of using very short servo extensions, both out of the receiver and at the end of the aileron servos, and to unplug the wing, I seperate the extension to extension conection vs unpluging and pluging into the receiver. If I run into a worn contact, it is much easier to replace the extensions and that would be plug cycle #2 for the receiver and servo contacts.
Don
The connectors in the transmitter and transmitter module can be connected and disconnected quite a bit. The intent was to enable the modeler to change the transmitting frequency at will. At some contests, this may be several times in a day.
That being said, if the connectors are torqued or bent while the module's being installed or removed, then they may fail.
We don't see that removing the module increases field safety if the modelers are careful about making sure their transmitters are turned off. If your friend feel more secure, then fine, no harm done.
The only real problem we see is if the pins are allowed to become dirty.
