Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Trim set up?
Old 06-21-2006 | 12:03 AM
My Feedback: (7)
Default Trim set up?
I have just set up a stik type plane with the quad flaps. I have everything working about the way I want it. My question is this, my aileron trim only works on the ailerons (channels 1&7) and not on the in board sections (channels 5&6). Is there a way to set it up so that the aileron trim will work on all four channels? I guess I should tell you that I am using a 9C super.
Steve
Old 06-23-2006 | 11:19 AM
Bax
Default RE: Trim set up?
When you mix the flaps as slave to ailerons, make sure "trim" is turned on in the mixer. Some of the mixers may not allow that, especially if you are using a pre-configured mixer in the transmitter. If you are using a Pmix, then you should have the "trim" option.
Old 06-30-2006 | 01:41 AM
Globemaster3c17's Avatar
Which plane are you trying to set that up on? That the one you designed yourself that you had framed up the last time I was there?
