14mz and 12mz model question
My Feedback: (8)
MA
how much are the models interchangable from the 14mzap to the 12mzhp if i create a heli model on my 14mz and move it over to my 12mzh will it work correctly? i am still working to figure out the 12 and i have had the 14 for long enough that i can get thru programing easy enough but they are different enough to be another learning curve.
thanks
thanks
CA
RE: 14mz and 12mz model question
Try it and let us know Seriously though I am told that models can be moved from 12 to 14 and will work like a champ. I have not tried this - as I can't imagine what I would do w/out the touch screen - aka 12 -but give it a shot and see if it works!
Hi darryl123,
As long as the name for the model being moved to the 12Z is 8 characters or less and the model of course doesn't use more than 12 channels, they are completely interchangeable.
Please see the FAQ and other 12Z FAQ's about this at:
http://www.futaba-rc.com/faq/faq-12z-q866.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: darryl123
thanks
thanks
My Feedback: (8)
MA
hi thanks for the answer krista.
here is another question.
the 14 mz is shift select but i cannot find any way to change the 12mz to positive shift, so if i create a model that uses positive shift in the 14mz for my blade cp will it work in the 12mz?
if not is there going to be a shift select update for the 12mz.
thanks
d
thanks
d
Hi Darryl,
At this time we have not heard if the 12Z will be updated to include the shift select feature.
If you have this in a model in your 14MZ it will of course, not carry over to your 12Z when you transfer a model.
Sincerely,
Krysta Hunt
Sincerely,
Krysta Hunt
ORIGINAL: darryl123
thanks
d
thanks
d
