Dual rate trim change
I have an 8UAP and I noticed that when I switch between dual rates, the elevator's trim position changes a few degrees. Is there a way to correct that?
RE: Dual rate trim change
Hmm, never thought it would be that. Everything else seems to work properly, and the trim position on high rate and low rate each time I switch is consistent. Although I know the radio was kept in great condition, it was used often before I purchased it, so I wouldn't be surprised if it needs a little maintenance. Is that a very complicated or expensive process and would I have to send it in to Futaba, or is that something I could easily do myself?
TIA
TIA
Recalibrating the transmitter takes but a few minutes in the service shop. Replacement of a stick pot is a bit longer. Cost to check out and calibrate a system with a computer transmitter, assuming nothing is actually wrong with the unit, is a flat $35.00 for your transmitter. If a stick pot had to be changed, then you'd be charged only the parts and labor for the job, no flat-rate applies, and it would cost about $45.00 or so. That also includes checkout and calibration.
Any transmitter that has dual rates that cause the trim to move when you flip the switch either is a real old one or needs work. Older units would move the trim when you changed rates. No getting around that.
