delete
Hi MSBOB,
How is your radio reacting? Are you gettting Aileron action? Did you make sure to use the 2 Aileron wing type? Are you trying this with Airbrake or Camber. If you are trying this with Airbrake, make sue that you have it activated, and set your percentages in "Tuning" not in Offset as there is a mistake in the FAQ for Airbrake...
Let us know more of how you have this set up, Krysta
ORIGINAL: MSBOB
I am trying to setup Flaperons using the Camber Mix Menu. I have looked at the Futaba 12Z FAQ site but the instruction for doing this were not detailed enough for me. I have Flaperons setup on the 9C and I am trying to duplicate the operation on this 12Z.
Any help will be gratly apprciated.
