Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
7CHP gyro settings
Old 07-25-2006, 03:40 PM
AJsToyz
AJsToyz's Avatar
Default 7CHP gyro settings
I was setting up my radio and having a little trouble with the gyro. If I set the radio to GY under gyro it should be in head holding mode, but it goes into standard mode instead. If I set it for STD the light on the gyro stay's on showing head holding mode , is this normal?? Also when programming the gyro it said to flip between HH and standard mode a few times , less than a second between flips of the switch. Can this be done on a 7C ? I cannot find it or how to set that up in the program.
