9C Four aileron set up MIX questiion
OK, I have CH1=right aileron, CH6=left aileron, CH7=right upper, CH8=left upper. Now to mix chennel 7 to work just like channel 1, can I just use any MIX and change it so CH. 1 is master, and CH.7 is slave? What about CH.8?, just go to another MIX and put CH.6 master and CH.8 slave?
RE: 9C Four aileron set up MIX questiion
If you are adding extra ailerons for a biplane, then the third and fourth aileron would all be mixed so that channel 1 is the slave. In a normal 2-aileron servo mix, the second servo is slaved to channel 1. Then to adjust the mix percentage and direction to the the proper amount of throw you want.
You are mixing a FUNCTION. In the 9C, channel 1 is the aileron FUNCTION, so you'd make multiple surfaces work with it as the master.
