Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Noise ?
Old 08-02-2006 | 02:24 PM
Default Noise ?
I have a new 1/4 scale plane and it is powered by a 42CC Taurus engine. With the engine running and transmitter antenna fully collapsed I get severe servo chatter when the transmitter is just ten feet from the receiver. If I touch the antenna with a finger the chatter goes away and I can walk back at least 50 feet with no problems. I tried two receivers and two transmitters with the same result. I moved the receiver antenna from inside the plane to the outside with no luck. The engine manufacturer is coming over soon to try a few things. Why would the servo chatter cease when I touch the antenna? Thanks in advance --- Ray
Old 08-02-2006 | 04:29 PM
Bax
Default RE: Noise ?
When you touch an antenna, the capacitance of your body is added to the antenna, and changes its characteristics.
Old 08-03-2006 | 04:29 AM
Patto's Avatar
Default RE: Noise ?
If you haven't already tried it, move all your servos as far away from any ignition and engine items as possible, including ignition wiring, ignition battery, ignition cut-off switch, etc. Also, make sure you are not using metal connections or pushrods for your throttle.
-Pat
