need help!! T7UAF Super setup for blade cp
Looking for ass. in programing 7uaf for blade cp
not sure if HLl2 is proper mixing type. and if I'm overlooking pos. swash mix
any help would be greatly appreciated......
WI
RE: need help!! T7UAF Super setup for blade cp
Try this link:
http://www.rcgroups.com/forums/showt...t=blade+futaba
I used this to set up my 7CAP & T6AS radios-works good.
You have to get a short single conversion crystal and install it into the 4-in-1.
HTH
Tom
HTH
Tom
My Feedback: (31)
PDR... The 7U series doesn't have the 120 degree mix you need on a swash setting (for eCCPM mix) for the blade CP. You can use programmmable mixes, but it will be more of a challenge.
The 7U transmitter doesn't have the proper type of CCPM mixing your heli needs.
It could be done by using programmable mixes, but the 7U Super transmitter doesn't have sufficient programmable mixes to accomplish what you need to do to fly your heli. You will need a more-capable transmitter to fly your heli with CCPM mixing.
