Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9CH super programming
Old 01-11-2007 | 01:57 AM
Default 9CH super programming
can this transmitter support a heli with 90 degree swash. The heli in question is the new raptor e620.
Old 01-16-2007 | 04:10 PM
Bax
Default RE: 9CH super programming
You can see illustrations of the different swash types at:
http://manuals.hobbico.com/fut/9c-su...ies-manual.pdf
Old 01-19-2007 | 10:13 AM
I still don't know how to set up the protech zoom 450, in ccpm mode can anyone help I have everything moving in the right direction. The swash plate level and the the swash adjusts to +50,+50and +50, but the pitch goes from -10 at low throttle to +5 at full throttle.
Peter
Old 01-19-2007 | 11:40 AM
Bax
You may need to check your pitch ATV or your throttle/pitch curve to see what's up.
For answers specific to your heli, you should ask in the heli forums.
Old 01-19-2007 | 02:54 PM
I have looked in the manual for ATV which says it is old name for end point. Do I just change the end points on the pitch servo. As far as the pitch/ the throttle curve he pitch curve(or so it says in the zoom manual) is a straight line. Is that usual for ccpm.
Peter
