9c/9c super campac compatability
I see on the Futaba site where models from a 9c can go into a 9c super although something happens with model #13 defaulting to model #1? I suppose I will figure that out on my own when I sit down with it. My question here is will I be able to use models that were programed originally on the 9cSuper in my old 9c? Also will all modle memorys stay intact? I wouldn't want to put the campac in my older 9c and have it not recognize things quite right and cause a problem. I figure at the least that some models wouldn't be useable as the 9c is an 8 model radio and the 9cS is a 12 model radio plus 6 with the campac I believe. If I understand things right the older 9c would only recognize the first 14 modles perhaps. Just don't want to loose the information but also don't want to toss the old radio I want to get it repaired.
I had the same problem. The 9c super configuration IS different than the 9c. The 9c super will still read the 9c campac but the 9c will not read the 9c super. The way the 9c super reads it is that you have to copy it to a memory spot on the radio every time you switch planes. It is a little confusing at first. That is why little by little I will switch everything over to my Spektrum DX-7!!!
R/C Foolish
R/C Foolish
