Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
servo wire adapter
Old 01-27-2007 | 05:18 AM
Default servo wire adapter
I have the sig something extra and it calls for duel aileron servos in the wings. It also calls for two 6 inch extentions for the servo wires. My question is....do I have to use a y-harness on top of that or is there some sort of duel connector I can hook to the 6 inch extentions and then hook that into my wire coming from my receiver? I'm using a futaba standard radio.
Old 01-27-2007 | 07:55 PM
Default RE: servo wire adapter
You do not need a y-harness. Normally 1 aileron goes on channel 1 while the other to either channel 6 or channel 7 depending on the mode you want to use.
Old 01-28-2007 | 10:24 AM
rcdivot,
Your initial post indicated you have a "futaba standard radio." By that I'll assume you mean it has only 4 channels. (One each for aileron, throttle, rudder, and elevator.) The response you received from darylp is correct, but intended for someone with at least a 5 channel transmitter that allows such options as flaperons and spoilerons by connecting separate aileron servos to different channels.
With a 4 channel radio, your only practical choice involves a Y harness from the receiver to each independent aileron servo. To save cost, you might shop around for a Y harness with extra long leads, thereby omitting the extensions. Try Radical RC for their selection.
Enjoy your SE... great airplane!
Windancr
Old 01-28-2007 | 11:00 AM
rcdivot,
I beleive they call for extension wires because the servo wires do not normally reach to the end of the wing tubes. In my Something Extra, I did use extensions, but at the receiver end because the servo leads did reach to the end of the wing tube and more. I would feed the leads through the fuse as I attach the wings, then make the final connections inside the fuse. If you are going with a y-harness, make sure your servo arms are mounted on opposite sides of the aileron servos so you will get opposite action and not flapping action.
Good luck.
Old 01-28-2007 | 03:17 PM
My servo wire only sticks out of the wing tube about 1 inch. Not enough for me to be satisfied with so I am using a 6 inch extention on each servo wire through the tube.
I was thinking maybe I could use the duel extention below in place of a y-harness that has too much wiring for me.
Would this work?
http://www2.towerhobbies.com/cgi-bin...?&I=LXH451&P=M
Old 01-29-2007 | 12:31 PM
Hi rcdivot,
If you are using a 4 channel system, you will want to use the Y-harness for both ailerons in channel 1. The dual extension you are looking at will be fine.
If you are using a 6 channel system or above you will want to place one aileron in channel 1 and the other in channel 6, which if you need more length, a regular servo extension FUTM3910 will be fine.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: rcdivot
Would this work?
Old 01-29-2007 | 03:55 PM
Krysta,
Thank you very much for your help!
Since I have the 4-channel Futaba radio, I will just use the dual extention rather than the y-harness.
Thank you.
