Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Interference problem
Old 02-16-2003 | 01:29 AM
My Feedback: (24)
Default Interference problem
This past Sunday, I prepared to fly my 4 star 40, which I have flown several times be fore with no problems. This aircraft is equipped with 127 df rx and using a skysport 6 Tx. Range checked and batts checked. The problem- turned on the Rx and all servos fluttered violently, turned on the Tx and every control suface went to nuetral and operated perfectly. This has not happend to my aircraft be fore but it has happened to others at our field. Needless to say, I did not fly this aircraft. All the other guys made sure all tx's were off and every thing. I am on channel 38, please HELP! Thanks TEEPEE
Old 02-17-2003 | 02:21 PM
HI TeePee,
From what you have described. "turned on the Rx and all servos fluttered violently, turned on the Tx and every control suface went to nuetral and operated perfectly. " This is what is causing the problem.
You should always turn your transmitter on before you turn the receiver on.
I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected].
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 02-18-2003 | 01:03 PM
My Feedback: (24)
Thank you for the info and quick reply. I will purpose to do this in the future. TeePee
