Using all 8 channels with R148DF
My Feedback: (9)
IL
I got a plane that is set up with 6 servos and 3 gyros. The two elevator servos are combined on one channel so I figured I needed to get 5 (servo control) and 3 (gyro gain control) = 8 channel receiver. I got the R148DF but I only see 7 open ports and one that is marked 8/B. Is this receiver sufficient for my application? How do I hook up the battery and still use all 8 channels? Also, I think I read somewhere that the last channel on R149 is an on/off only channel. Does this also apply to channel 8 on R148? Can I still use this channel for gyro gain control if I wanted to control it by a two position switch and say that I wanted to assign 0 and 50% gain for the two switch positions.
I will be using this receiver with 9CAF radio.
![](/forum/images/badges/trading_plus_member.png)
Actually, I would guess it depends more upon the TX than the RX. If the TX has a switch it's on/off, if it has a pot it's proportional. On some TX's it is assignable.
Oops, sorry BAX, forgot this wasn't open forum.
