Futaba 7C TX
Futaba 7C TX
Hi,
I am a Futaba user and right now I am using the 6YF TX with an R147F RX, (both on 35MHz).
Now I am intended to upgrade my TX to the 7C but will the current receivers I have (R147F) be compatible?
thanks in advance for you help
RE: Futaba 7C TX
Hi mouthpiec,
Unfortunately as we do not carry the R147F, nor use 35Mhz here in the US, we would not be able to help you with this question. You would need to contact the place of purchase for this information.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: mouthpiec
Hi,
Hi,
RE: Futaba 7C TX
my question is the following because the frequency is irrelevant if both TX and RX use the same band (in my case 35MHZ);
is a Single Conversion RX compatible with the 7C?
thanks again for the help
RE: Futaba 7C TX
Yes it is compatible.
Sincerely,
Krysta Hunt
Sincerely,
Krysta Hunt
ORIGINAL: mouthpiec
RE: Futaba 7C TX
Hello i belive that this is the place were i could get help on this so.... I have this Futaba 7CAP and now i have this problem :When I increase the throttle, the rudder moves slightly. It looks like a mix is on but it isn't. I would say about a 20% mix. It is there even after a reset on all model memories. I tried two different receivers (both FUTABA) and it has the exact same problem….It was in acro mode. I also switched it to heli mode and revo mix is off (inh) by default. This makes me to believe that there may be a software issue. Can I have some help on this?
