Futaba 2.4GHz FASST and flight sims
RE: Futaba 2.4GHz FASST and flight sims
Hi rajul,
You do not need to set anything, this will work fine with Realflight as it is a PPM signal. You may need to remap your controller in the software program but that is all.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: rajul
What do you need to set in a 2.4GHz FASST radio to get it to work with a flight sim? Can you set the signal output from the trainer/DSC port to PPM mode?
