Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9c offset
Old 05-10-2007 | 11:22 PM
Default 9c offset
I have a 9c an in the advance mode I was mixing flap to elev I went to offset
what is offset an how do you adjust it right now I have it set at 51 percent an I am unable to put it back to 0
Old 05-14-2007 | 11:38 AM
Default RE: 9c offset
Hi Kerwin, I am assuming you are talking about the Offset point in the Flap to Elevator mix you are in?
Offset mixing allows you to change the center point of the mix away from the sticks ( or knobs ) center position.
To move this offset back to zero, you will need to into the offset of this mix, actually move the Flap knob to the center of its position then press and hold down the dial until you see the highlighted number for offset go back to zero.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: kerwin50
Old 05-21-2007 | 06:47 AM
Than you
