6EX-2.4 Programming Question
Does the 6ex-2.4 allow you to program for split elevators using two servos or do you have to use a reversing y connctor?
Do you have to use a y connector on the ailerons also?
Hi DR10044,
The 6EXA 2.4GHz has the same basic programming as the reqular 6EXA, so you can use the FAQ's from the older radio if you are looking for programming information.
As for dual Ailerons, you will simply need to activate the FP or Flaperon mix. Dual elevators would need to be set up using your free PMix, but there is no way to get the radio to allow trim for both servos in Dual Elevators. If this is needed your best bet is to purchase a Synchronizer FUTM4155.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta
