Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9CHPS & Removing RF Module?
Old 06-06-2007 | 10:54 PM
franklin_m's Avatar
Default 9CHPS & Removing RF Module?
Without damaging the transmitter, is it possible to remove the transmitter module and then play with the programming?
Also, in related question, I know it's not good for long term health of a RF transmitters to send the signal into an unmatched load. This would be the case when the transmitter is on, to experiment with programming for example, with the RF module installed and the transmitter collapsed. So, does this damage the 9CHPS?
Old 06-07-2007 | 04:53 PM
Bax
Default RE: 9CHPS & Removing RF Module?
Yes. If you remove the module, you can run the transmitter for programming as long as the battery pack holds out. You won't damage a thing.
If you want to change some programming and you don't remove the module, then have at least the largest section of the transmitter antenna extended.
Old 06-14-2007 | 05:43 PM
franklin_m's Avatar
Thanks Bax! Love the product...want to make it last.
