12Z Servo Sync issue
My Feedback: (20)
I have a 12Z with a PCM reciever and cannot figure out why the left elevator servo plugged into channel 1 moves the control surface about 1/8 inch before the servo plugged into channel 2 (right elevator) moves. I'm using Airplane with 2 ail wing and Ailvator for tail type.
All ATV, EXPO are the same for both directions and sub trims are at ZERO. I have a Rudder to Aileron mix and a Rudder to Elevator mix. No other mixes.
I'm not sure where to look for the problem at this point. I'm using all HD servo ext and digital servos.
Thanks for your help
Jeff
Jeff
