Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Voltage limitations and recommendations?
Old 11-27-2007 | 03:02 AM
Default Voltage limitations and recommendations?
What is the maximum voltage that the new 5114 Rx can be operated with? A good 5 cell NiCad pack can get up to 7+ volts fresh off the charge. Can a 2 cell lithium (8.4 volts or so) be used without a regulator? Also what does Futaba recommend as the optimum voltage to operate this Rx at?
Same question for the other Futaba receivers?
And same question for Futaba servos?
Bryan
Old 11-29-2007 | 05:57 PM
Bax
Default RE: Voltage limitations and recommendations?
You would not operate with more than a 5-cell NiCd or NiMH battery pack. Please be aware that some Futaba servos are limited to 4-cell NiCd or NiMH packs. There is no specification for other types of battery packs. Normally, you'd regulate at just under 6.0 VDC. If you have a system that can regulate at that voltage and provide enough current to the servos, you can use any battery pack that will provide the voltage and current. A 2-cell Lithium pack without regulator is definitely not recommended.
Old 11-30-2007 | 04:00 PM
Bill,
I am flying the 6EX FAAST S3152 digital servos with a 5 cell NiMX. On a fresh charge my RX battery puts out 7.1V to 7.2V After 2 flights, the voltage is down to 6.7v and after 4-5 flights voltage is down to 6.3.I am not using a regulator, just a straight vanilla hook-up. The system is working perfectly. Need I have any concern about the 7 volts? Another thing, I heard is that NiMH batters do not develop a "memory" and do not need to be cycled. Is this true?
JC
"I've got 3-green"
