Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Difference between 9C and 9C Super?
Old 12-17-2007 | 08:47 AM
Default Difference between 9C and 9C Super?
What's the difference between the 9C and 9C Super? I just got a second-hand 9CAP and am wondering if I'm missing anything over a 9CAP Super?
Old 12-17-2007 | 05:46 PM
Bax
Default RE: Difference between 9C and 9C Super?
Features are compared here: http://www.futaba-rc.com/radios/feature-compare.html
Old 12-19-2007 | 05:30 AM
Thanks Bax! Very informative chart.[8D]
Old 12-20-2007 | 11:10 AM
Hello!
Radio System Feature Comparison
FEATURE 9C 9C Super
Number of Channels PPM:8 PCM: 9 PPM:8 PCM: 9
Select mode YES YES
Modulation FM/PCM FM/PCM
Uses Module? YES YES
Optional Synthesizer? (5) YES YES
Trim Type(19) D (4) D (4)
Store Trims(20) auto auto
ATL throttle throttle
Sub Trim YES YES
Servo Reversing YES YES
Servo Slow NO NO
Servo Display YES YES
Transmitter Voltage digital digital
Receiver Voltage NO NO
Trainer(30/31) as student: YES YES
Trainer(30/31) as master: YES(2) YES(2)
Dual Rate YES YES
Expo YES YES
ATV YES YES
Low Batt Warning YES YES
Computerized YES YES
Acro Programming YES YES
Heli Programming YES YES
Sail Programming YES YES
Multiple Models 8(21) 12
Model name 8-char 8-char
User Name NO NO
Programmable Mixes - Linear 8 Total 3A/S 5H 10 Total 4A/S 6H
Programmable Mixes - Curve 2A/1H 3A/2H
Timer YES -2 YES -3
Tachometer NO NO
Data transfer(23) YES YES
DSC w/ compat Rx YES YES
Switch Assignability nearly all nearly all
Inflight Mixture NO NO
Engine Start YES YES
FailSafe(3) YES YES
Batt FailSafe(3) YES YES
Trim step adjust YES YES
Function assignability MOST MOST
Channel assignability(17) 5-9 only 5-9 only
Conditions 1 1
Servo movement display YES YES
Dual Rate/Triple Rate YES(18) YES(18)
Logic for Switches NO NO
RF ON/OFF NO NO
Shift Select (PPM only) NO NO
FEATURE 9C 9C Super
Revo Mixing(24) 5-point 5-point
Hover Pitch knob knob
Pitch Curve(24) 5-point w/Delay
Pitch Rate(26) NO YES
Pitch Trim NO NO
Throttle Hold YES YES
Throttle Curve(24) 5-point w/Delay
Hover Throttle knob knob
Throttle Cut YES YES
Idle Up 3 3
Offset(s) YES YES
Swash Select 1, 2, 4, R3, N3 1, 2, 3, 4, R3, N3
Swash AFR YES YES
Swash-Thr Mix NO YES
Swash Rotation YES YES
Delay YES YES
Gyro Prog(28) YES YES
Governor Prog(28) YES YES
Invert Switch NO NO
Invert Cross NO NO
Conditions(27) NO NO
Rudder to Thr Mix NO NO
Rotor Direction NO NO
Swash Type(14) 5 5
Acceleration Mix NO NO
Swash Ring NO NO
Inflight needle set up YES YES
Throttle Limiter NO NO
FEATURE 9C 9C Super
Flaperons YES(29) YES(29)
Air Brake YES YES
Aileron differential YES YES
V-Tail YES YES
Elevon YES YES
Ailevator YES YES
Snap YES YES
Ail 2 Rud Mix use pmix use pmix
Flap 2 Elev Mix use pmix use pmix
Elev 2 Flap Mix YES YES
Idle Down YES YES
Throttle Curve use pmix use pmix
Flap Travel or Trim YES YES
Throttle delay YES YES
Inflight Needle Setup YES YES
Gyro Mixing NO YES
FEATURE 9C 9C Super
# Wing Servos 2 to 3 3 to 4
Butterfly (16) Sw A only YES
Start YES YES
Speed YES YES
Ail 2 Flap Coupling FLP2 only FLP1/FLP2
Flap 2 Ail Coupling YES YES
Compensation Mix use pmix use pmix
Elev 2 Brk use pmix use pmix
Flap Coupling use pmix use pmix
Trim on Switch use pmix use pmix
Camber Mix NO 4-Circuit
Offset Trim 2-Circuit 3-Circuit
