9Cs latency
WA
I have been reading about a latency issue with using channels 2 and 8 on dual elevator set up's.
I am wondering what can be done about this. I have the same set up using 2 and 8 as ailevator
and channel 8 seems to be slower. I know I have linkages and mechanics of control arms set up
identical. I am just wondering if this is a common problem and if I mix another channel rather than
8 if I can have better luck?
Please see our FAQ page, particularly this FAQ:
http://www.futaba-rc.com/faq/faq-8u-q594.html
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: 3DAP
WA
Will switching to 2.4 module help this?
Is there only a 8 chan module, receiver?
Is it available yet?
Will there be a 9 chan module and rec?
THANKX AND HAPPY NEW YEAR
Hi 3DAP,
Switching to 2.4GHz will not help this. This lag that you are noticing on the ground is generally so minor it will not be noticable in the air. As far as if there is going to be a 9ch 2.4GHz FASST combo, we have not been told yet. The TM-8 module/receiver combo should be available around the end of the month.
Bax's answer to this in a previous post may help you out a little with this:
http://www.rcuniverse.com/forum/m_29...tm.htm#2981157
Sincerely,
Krysta
Sincerely,
Krysta
