Glitching Problem!!
CA
A few months ago after having my hilo sitting around for 3 months, decided to fly it again. Had a PCM 1024 Rx on it, but when I radio tested, found a glitching problem. So I started testing with other batteries (thinking that the low power of the battery after been sitting around for a long time could be the problem), but problem remains, so tried whit other Rx the Futaba FP-R148DF and the glitching problem was resolve at that time. Started flying my hilo for some time and then put it away.
Now after a month and a half, cleaned the dust off my hilo and proceed to fly it again, but for my surprise found some glitching again but now with this Rx. The first time I thought the problem was the PCM 1024 Rx, so I put another Rx but now the one that I have on my hilo (FP-R148DF) is glitching as well after a month.
I don't think the transmitter could be doing this glitching since I have been flying other model planes with it.
The Transmitter is a Futaba T9CHP with a TP-FSM 72Mhz Synthesizer.
Could be only dust inside both RX that might be affecting their performance or might be something else?
I really appreciate any suggestions..
Juasiel
Juasiel
Hi juasiel,
We seriously doubt that dust would be a problem, but depending on how and where the receivers and heli's were stored, it cannot be ruled out. We would more suggest you look for loose nuts and bolts in your heli setup, or loose connections as something that may be causing your glitching.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: juasiel
Now after a month and a half, cleaned the dust off my hilo and proceed to fly it again, but for my surprise found some glitching again but now with this Rx. The first time I thought the problem was the PCM 1024 RX the problem, so I put another Rx but now the one that I have on my hilo (FP-R148DF) is glitching as well after a month.
Juasiel
Juasiel
