Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9 cap with faast module?
Old 02-13-2008 | 12:19 AM
Default 9 cap with faast module?
Looking at getting a faast module for my 9cap.
Would a 9cap with a faast module have as good latency as an inbuilt system?
Old 02-15-2008 | 12:57 PM
Bax
Default RE: 9 cap with faast module?
When you add a Futaba FASST module to a 9C transmitter, you will find no degradation in latency. However, it won't speed up, either, because latency is determined by the processor. That being said, though, because you need to set the transmitter to PPM mode to use the module, you'll have a somewhat faster latency because PPM mode is a bit faster than the PCM mode.
If you're not flying complex CCPM helis, then latency becomes rather moot, since that's where most testers have concerns.
