Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9ZAPWC2 Module
Old 04-20-2003 | 03:15 PM
My Feedback: (20)
Default 9ZAPWC2 Module
I have two modules for my 9Z, standard single channel and the synthesized. If I change modules and power up the radio all I get is a straight horizontal line.
I power down the radio remove the battery, place the battery back in the radio and it works.
Is this the correct way for this to react?
Jeff
Old 04-21-2003 | 03:54 PM
Hi Jeff,
You should not be experiencing this type of response when you change your modules at all. You should not have to remove the battery, nor should you see a horizontal line.
It sounds as though you have a problem in the transmitter itself, and I would suggest that you send that into our Service Center to the technicians here can check this out for you.
Please see our site at: http://www.futaba-rc.com/service-moved.html for information on returning this to our service center.
I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected].
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 04-25-2003 | 12:24 PM
My Feedback: (20)
Thanks Krysta.
