Exchanging models between 14-MZ and 12-FG ?
Is it possible to exchange model files between a Futaba 14-MZ and a 12-FG ? Are the model files compatible ? If not, is this planned in the future or does some sw exist to convert them ?
Ralf
Ralf
RE: Exchanging models between 14-MZ and 12-FG ?
There isn't an easy way to move model settings between a 14 MZ and a 12 FG. Their file systems are quite different. The only real way is to go through all the menus and write down the settings. Then reproduce them in the second transmitter.
There is no software to do this. It must be done manually.
OH
This answer is not correct!
There is a software by which you can transfer your model data from and to the SD Card of thhe T12 plugged in your computer. Same you can do without any problems with your flash memory card being in your 14MZ. The program works only for model data.
regards
Juergen
regards
Juergen
