Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Help programming a mix in a 7C
Old 03-20-2008 | 10:35 AM
Default Help programming a mix in a 7C
I'm trying to program in the following mixes:
PROG - MIX1:
ELEV->THRO (Ch2 -> Ch3)
Down -20%, Up +20%
PROG - MIX2:
AILE->THRO (Ch1 -> Ch3)
Left +20%, Up -20%
Maybe I'm having a brain fart, but I cannot seem to figure out how to get these setting in!! Any step by step would be greatly appreciated!!
Old 03-20-2008 | 04:05 PM
Bax
Default RE: Help programming a mix in a 7C
It looks like you have the idea about what you want to do. Pages 53-55 in the 7C manual give you the mechanics of how you actually input the parameters for the mix: which switch, which channel is master, which channel is slave, and the amount the slave moves when you move the master.
Old 03-20-2008 | 04:06 PM
I don't understand the down/up and left/up stuff! Do I move the stick that direction when I make the settings?
Old 03-20-2008 | 04:14 PM
Bax
If you are making a mix with elevator as master, then you move the stick one way and you'll see one of the %-signs flash. Turn the dial to change that number. Move the stick to the other side and the other %-sign will flash. Turn the dial to set that number.
We don't know what you mean by the down/up, left/up stuff. The percentage of mix determines how the slave channel will mix with the master. If the servo moves the wrong way, just rotate the dial until the "+" becomes a "-" or vice-versa.
Old 03-20-2008 | 04:30 PM
These two statements:
Down -20%, Up +20%
Left +20%, Up -20%
Do I move the stick Down, then set to -20%, then move it Up and set it to +20%? etc.
BTW, this is to mix the throttle with cyclic movement to compensate for drag on the blades to keep the altitude close to the same
Old 03-20-2008 | 06:37 PM
Never mind, I figured it out - you have to move the master control to switch between the two settings.
