Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
TOLEDO!!
Old 04-01-2008 | 09:23 AM
Bax
Default TOLEDO!!
There will be a testing station at the Great Planes booth at the Toledo Show. If you bring your 6EX FASST transmitter, your 7C FASST transmitter, or your other transmitter with the TM-7 FASST module, it will be checked to determine if it has a coding issue. If your 6EX falls within a certain serial number range, it will have the software updated. 7C transmitters will also have their software updated.
If you have a 6EX transmitter that isn't in the serial number range, or you have an affected TM-7 module, you will have to then send them to the Futaba Service Center for update.
If your 6EX FASST transmitter, 7C FASST transmitter, or TM-7 FASST module already has the small, white sticker with the letter "I", your unit doesn't need to be checked or updated. It's already been done previously.
The representatives at the Toledo show WILL NOT be able to accept units for transport back to the service center.
