Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12FG flap programming help needed
Old 04-10-2008 | 09:47 PM
f106jax's Avatar
My Feedback: (16)
Default 12FG flap programming help needed
As a recent convert from a JR10X, I'm still muddling my way through the differences in Futaba / JR programming. I've programmed a 2 ail / 2 flap set up and have assigned the flaps to the SG 3 pos switch. They are working in the right direction but I am unable to figure out how to adjust the throw for the mid and full down position. Any help would be greatly appreciated!
Mike
Old 04-11-2008 | 09:20 AM
Bax
Default RE: 12FG flap programming help needed
If you have a specific "Flap" channel, just adjust it in AFR. You can set points in the "POINT" curve option. Select that option and then you can set the travel of the flaps however you desire.
Old 04-14-2008 | 08:12 AM
f106jax's Avatar
My Feedback: (16)
Thanks very much for your quick reply. My mind was focused on looking for the "mid" and "land" screen. Love the radio, still re-training my brain.
Thanks again!
Mike
Old 04-14-2008 | 10:43 AM
In the Haze's Avatar
On a similar problem when using the camber mix to elevator on a 3 position flap switch. The rate 1 always uses the 1st position of the switch where you actually don''t want any mix as the flaps are up. The rate 2 mixes in the middle switch position and then nothing when the flap switch is in pos 3 or full flap.
I got around this by doing a seperate prog. mix and using the spline curve. But this is defeating the object of a dedicated mix, or am I going mad here?
Edit: This is the 14mz not sure if 12FG is the same.
