Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Any pointers to help programming mixing on 12FG?
Old 05-12-2008 | 04:24 PM
Default Any pointers to help programming mixing on 12FG?
Anyone got a good pointer to a document that shows how to program mixing on the Futaba 12FG?
Some kind of quick start guide, cookbook, or annotated screen shots would be helpful.
I'm wanting to program nose down elevator with flap deployment, for example. In the future, I'll
need to program CROW for my turbine jet models.
Thank you,
Chris Shaker
[email protected]
Old 05-19-2008 | 09:42 AM
Bax
Default RE: Any pointers to help programming mixing on 12FG?
There currently are no books available that will give you the details you desire. If you want elevators with flap deployment, use the mix that's already in the Model Menu. First, make sure you have a wing type selected so that you have flaps of the type you're using. Once you have that, you can then set the mix. Use the "Camber Mix". It will allow you to set the interaction of elevators, flaps, and ailerons in one mixer. It will do it all for you.
