10C ailevator function
The Futaba 10C has a faster, newer-technology processor that virtually eliminates the lag between mixed channels. This will be noted when the transmitter's broadcasting in the 2.4 GHz FASST mode. If you are using PCM1024 mode, then the performance will be similar to the 9C and 9Z transmitters.
