Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Servos
Old 08-04-2008 | 08:21 PM
Dano101's Avatar
Default Servos
I started a project about 14 months ago (Top Flight Beech Stagger Wing). I have six (6) Futaba S9001's and one (1) S3303 servos installed. Aircraft has not been in the air. I recently purchased the Futabe 10C with the R6014FS receives. Question; will these servos work with the 2.7 volts from the R6014FS receiver or do I need to add amplifers, such as the ElectroDynamics amps in line to the servos? Just want to be on the safe side. Could not find the volt rating for these servos.
Old 08-05-2008 | 04:25 PM
Bax
Default RE: Servos
Your Futaba servos are fully-compatible with your Futaba receiver. The voltage "problem" involves use of non-Futaba items with the Futaba receivers.
Old 08-05-2008 | 05:32 PM
Dano101's Avatar
Default RE: Servos
Bax, thanks so much.
