Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
8UAPS Warning
Old 10-05-2008 | 02:00 PM
Default 8UAPS Warning
I have a 8UAPS radio. I turned on the radio yesterday for my first flight, moved all the control surfaces to make sure everything is working properly, and everything was working. We stated the engine, throttled up to clear and warm up the engine. I then looked down at the radio to set the timer and the only thing on the screen was "WARNIN", and nothing else, and I had no control of the plane at this point. I turned the ignition off to kill the engine, then i turned the transmitter off then on and every thing was working fine.
What does the warning mean? it was similar to a throttle cut warning but there was no beeping, it didn't say throttle cut, and I had no control of the plane.
Stephen Latus
Old 10-07-2008 | 01:32 PM
Default RE: 8UAPS Warning
Hi Stephen,
Whenever you see something like this and it is not indicating the reason for the warning ( Throttle cut/ Idle Down), then please send this into the service center. While this could show up only intermittently, it could be pontentially dangerous if it is indicating a component failure on the main board.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
